PXI
PXIe-2531 voltage limit
On the PXIe 2531 matrix, I noticed that there is a maximum voltage of 60VDC, but the datasheet is not clear as to why. Where does this number come from?
(1,643 Views)
The 60V limit might potentially come from the Reed Relays used at the crosspoints. Exposing the reed relays to high voltage or current will shorten the lifespan.
Santhosh
Soliton Technologies
(1,552 Views)
