Question 1: Is it possible to adapt the following NI PXIe-1082 system to perform basic diagnostics that can verify/check that all relays on PXIe-2532B are functioning correctly (Not sticking)?
Question 2: We are currently only using approximately 50 relays per PXIe-2532B out of 512 available relays, is it possible to change the relays used in the software when first 50 relays have reached the maximum switch count?
NOTE: The NI PXIe-1082 System is operating on Windows 7 (64 bit) and LabVIEW 2016.
