PXI
PXIe 1073 Power On Start
Hello.,
I have a PXIe 1073   system
I want to start it automatically when there the Mains  Power is connected.
any clues !!
(8,239 Views)
Dear aparab,
as far as I understand your inquiry, you'd like to boot a pxi controller without pressing the on-switch. The PXI chassis has three different methods on how to power on: Wake-On-LAN, an inbuilt switch and a BIOS setting. Details you can find in the following article.
Remote Power of a PXI Chassis
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIIuCAO&l=en-US
with regards
AndGar
Andreas Gareis
Senior Applications Engineer, NI
Certified LabVIEW Developer & TestStand Architect
(8,226 Views)
My PXIe-1073 doesn't have an embedded controller, are there no options for me other than to press the button every time I need to use the test rach it's installed within?
(6,508 Views)
hi,
u have to checkur system BIOS  and  find any Power-On function and  activate it.
NI  has a plugin or workaround for the BioS issue for pxie 1073  install that and it will run.
contact support and ask them abt the workaround. I recollect having done that.
regards,
akshay
(6,494 Views)
rkmadse,
See this link for a utility that allows you to configure the 1073 to power up when the host powers up.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIEECA4&l=en-US
- Robert
(6,491 Views)
