12-13-2011 05:05 PM
1. I wish to buy a PXI current type with higher Analog Inputs (32)and a Counter/time which can help in measurement of rotary type of encoder with 10bits.
http://www.autonics.com/products/products_detail.php?catecode=01/06/02&db_uid=202
2, Also suggest a PXI voltage type, with higher Analog inputs(32) and couter/timer which can help in measuremnet of rotary type encoder with 10bits.
12-14-2011 07:36 PM
Hi KRAZE4LV,
You can use the PXI Advisor (http://www.ni.com/pxiadvisor/) to help you find PXI products that match your needs. There are multiple PXI products that will fit what you are looking for. I would highly recommend talking with your Technical Sales Representative to narrow down the options and make sure that you are purchasing products that will specifically fit your needs. Thanks!
Cheers,
Carisa
