PXI
PXI trigger level to low
Any suggestions on how to trigger a camera digital input using PXI?
My camera has opto-isolated digital inputs and requires  3-25V input for min. 20 msec to turn high.
Power and digital I/O connection for A50/A70 and A400/A500/A700 (custhelp.com)
Right now I trigger the camera using PFI from waveform generator,since the trigger needs to set in relation to generated waveform, but this works only for 90% of the time, since the pfi level is too low (2.9VDC open).
I would prefer a fast switching solution, so no reed relays or additional optocoupling please.
Generator: PXI 5441
Digital IO(crazy connector) PXIe 6515 available
Matrix(reed) PXIe 2541 available
CLA
(1,644 Views)
Accepted by topic author Quiztus2
Do you want to avoid optocouplers for their propagation delay?
Any component in the path is going to add a propagation delay than having nothing. The question would be how much delay is tolerable. You need to convert the 0.2V-2.9V signal levels into CMOS levels (something like mc74vhc1gt126 with a TTL input and CMOS output with just 3.5ns prop delay at 5V)
Santhosh
Soliton Technologies
(1,629 Views)
Thanks a lot, that one gave me headaches. Didn't know of their existence: Noninverting Buffer / CMOS Logic Level Shifter - TTL−Compatible Inputs
CLA
(1,622 Views)
