09-28-2017 01:06 AM
We just received an email that one of our product is reaching EoL so I am digging into future alternatives and I am quite confused on what is the update path for people that have been using a chassis which provided bot the windows environment and the real-time environment on the same chassis.
Has this product design been dropped?
As the hypervisor solution was perfect for small footprint systems, I cannot seem to find an alternative that provides the same rich UI/UX with deterministic control.
Has the compact all-in-one use case been dropped?
Please advise
09-28-2017 09:21 AM
Hey,
Generally there has been a move to use a small windows PC along side a real-time PXI rather then splitting the PXI in half functionally. But the best optional for your case would be to call the local NI office and see what they can recommend for your use case.
09-29-2017 03:12 AM
NIJimbo is right, there was a shift like he mentioned.
To get the right suggestion what device you should use in the future I also recommend to call NI directly.
Best wishes
02-04-2019 06:17 AM
Hi
I have a NI PXIe - 8135, we run both "Windows 7 64bit" and "LabVIEW Real-Time" operating systems on PXI.
I want to run both operating systems simultaneously on PXI. So in NI tutorial found that NI Real-Time Hypervisor for Windows software enables to run simultaneously (http://www.ni.com/tutorial/11801/en/ )
In this link in section "1. Factory Preinstallation" said this software is preinstalled, but I can't find in this path [ Start >> Program Files >> National Instruments>NI Real-Time Hypervisor Manager]
Then I decided to install it and found that NI Real-Time Hypervisor 3.0 for Window software supports Windows 7
but I can't found Hypervisor patch version 3.0 (http://www.ni.com/en-rs/support/downloads/software-products/download.hypervisor.html )
Please help me how to run "windows 7" and "LabVIEW Real-Time" simultaneously on PXI?
Regards.
02-05-2019 02:53 AM
Unfortunatelly the NI Hypervisor is not supported anymore and will not be published because of that.
The Downloads are to patch your NI Hypervisor if you already have it installed but only for that case.
