Hello
I am trying to use an Aerflex 3030 RF Digitizer with a PXI which has the PXI-8106 Embeded Controller.
The Controller has Labview 8.5 Real Time installed on it. I am useing a Laptop as a Host and the PXI as a Target.
I have taken the steps necessary to have the controller recognize the 3030.
I also generated the drivers for the 3030 digitizer using the Labview Interface Generator for LabWindows/CVI Instruments Drivers.
Currently I have the following problem
Everytime I try to deploy VI's (which make use of the 3030 driver) to the target I get the following errors
On the Host
Failed to download af3030 VXIpnp Error Converter.vi
LabView: Failed to load shared library af3030_32.dll
On the Target
Error loading 'WINMM.dll': Missing export '_CxxFrameHandler3' from MSVCRT.DLL
Does anyone has a solution to this problems?
Thank you
