I am experiencing some problems installing a PXI-PCI8331 MXI-4 controller under Windows 2000.
After having installed LabView 7.1 and DAQ and DAQmx 7.3 and the software that comes with the PXI controller CD (NI-VISA), windows does not recognise the PCI controller card and asks for a driver. If I ask to the operative system to scan the CD from drivers, no driver is found.
If I open MAX, the PXI controller is unidentifyed. If I try to right click the mouse and select "Identify as...", MAX asks for a cntrller.ini file, that I am not able to find nor on the CD nor on the whole computer's filesystem (nor on the filesystem of a computer where such installation works properly).
The computer on which I am experiencing such troubles is a Dell Dimension 8100 (a P4 machine), with, as anticipated, MS Windows 2000.
Thanks in advance for any help,
Andrea Borsic.
