PXI
PXI Digital I/O Module
Hi all,
I'm looking for a PXI Digital I/O Module compatible with Siemens  Function Module :
 - FUM210-6DP1210-7AA
 - FUM211-6DP1211-7AA
Any help please.
Ahmed
(1,670 Views)
It would be good to share the datasheets so that we can look into the number of digital lines required.
In general, these information are required to choose the PXI card,
  1. Number of digital lines
  2. Input or Output
  3. Dynamic IO - change from Input to Output on the fly
  4. Sampling rate - hardware-timed or on-demand from software
  5. Voltage levels - fixed or configurable
Santhosh
Soliton Technologies
(1,642 Views)
hello,
I can't find the data sheet online for these modules, i have only the description below :
-MODULE FUM 210 FOR SENSOR CONDITIONING FAST BINARY SIGNAL ACQUISITION, OR DRIVE CONTROL SENSOR, MONITORING AND SIGNAL. MODULE CONDITIONING: 14 CHANGEOVER OR 28 SINGLE CONTACTS WITH SENSOR SUPPLY AND MONITORING, 28 BINARY INPUTS WITHOUT SENSOR SUPPLY + 16 BINARY OUTPUTS DRIVE CONTROL: 5/8 MOTORS, 5/8 SOLENOID VALVES 4/5 ACTUATORS, 3/4 STEP CONTROLLERS, 2/3 REVERSING ACTUATORS, REDUNDANT USE POSSIBLE, SIGNALLING AND MONITORING FOR SIGNALLING CONTACS OF THE CABINET, OUTPUT OF GROUP ALARMS
MODULE FUM 211, BINARY SIGNAL COUPLING MODULE 16 BINARY INPUTS WITE ELECTRICAL ISOLATION VIA OCTOCOUPLERS 16 BINARY OUTPUTS 250 MA (WITH LIMITATION) STEADY OR FLASHING (8, 2, 0,5 HZ) SUITABLE TO CONNECT CONSOLE CONTROL TILES. CAPABLE FOR 2 DESK TILES USE IN SPPA-T200
(1,633 Views)
