12-25-2024 07:44 AM
I have a PXI system that detects 4 CPU cores, but only one core’s data is visible on the screen. Even with a simple VI running a basic while loop, CPU usage shows 100%.
Has anyone experienced this issue or know potential causes? Any guidance on resolving this would be appreciated.
Thanks!
12-25-2024 07:00 PM
Put four independent while loops, and you will see the usage on multiple cores (don't highlight execution).
12-26-2024 05:53 AM
Thanks but the problem is even more complex vi’s, there is only one cpu is shown and total load is %100. İ tried 4 parallel while loops and problem is still same. But it also says “Labview Real-Time Single-Core Kernel found 4 CPU cores”
01-10-2025 11:58 AM
Is this with PharLap or Linux RT? If with PharLap, make sure to have "NI RT Extensions for SMP" installed in the software list for that PXI.
Hope this helps!
