10-22-2008 12:48 PM
I would like to set the Ethernet speed to 10BaseT on the PXI 8106 that I am using. It is communicating through an OLD hub (1998?) and seems not to be able to maintain a connection with the PC through that hub. In MAX, under Advanced Etherenet settings, I have only the Autosensing option, the rest of the pulldown is greyed out.
Is there any way to limit the PXI to 10BaseT. I would try this except that the old hub is VERY expensive (Fiberoptic Multiplexer). My work around is an industrial switcher to interface the PXI chassi to the Old Mux.
10-24-2008 01:24 PM
Hi SolarburnDOER,
I see an autonegotiate option but not an autosensing option in MAX under preferred media mode. And nothing is greyed for me under this mode.
Can you post a screen of what you saying?
Thanks!
10-28-2008 11:57 AM
Here is a screen shot. As you can see I only have the autonegotiate setting avaliable. I called it the autosensing option in my first post, hope that did not cause too much confusion.
Kevan -
10-29-2008 01:37 PM
Hi Kevan,
Here is a screen of my PXI-8106 with all the options. Can you see if you get the same issue if you connect the PXI directly to a Host?
Thanks!
10-30-2008 02:46 PM
I plugged in directly with a crossover cable. I had the same image as i posted above.
I am currently running labview 8.2 (Aug.2006) except when we got the PXI chassi, I had to upgrade to the drivers that came with the PXI (April 2007). Not sure if that helps at all.
I attached an image of the software installed on the PXI.
Kevan -
10-31-2008 04:15 PM
Hi Kevan,
This is most probably caused due to the difference in the Intel Ethernet Driver. You will need the Intel 8255x driver. This driver might be available in the Target CD that was shipped to you. If you cannot find the driver on the Target CD, post back with your version of the Target CD.
Thanks!
11-03-2008 02:06 PM
It looks like I have version 2.1 of the Target Software for the PXI. I was able to install the Intel 8255x 10/100Mbps Ethernet Driver, however, my version number was 2.1.0.3.0. I did not get the option to set the rate down. I have attempted to run with my old drivers and that did not seem to work.
Kevan -11-04-2008 04:26 PM
Hi Kevan,
I need to do some testing at my end and the get back to you. I appreciate your patience on this.
Thanks!
11-07-2008 01:49 PM
Hi Kevan,
I just tested out the PXI 8106 with older versions of ethernet drivers and I am still able to see all the options in MAX (check attachment).
The good news is that now we know its not the ethernet driver that is the problem.
Can you try reformatting your controller to see if that helps?
Thanks!
