06-10-2014 03:04 PM
I have a PXI-8512 high speed CAN module in my system. My PXI controller has a realtime OS. I am having some problems and have been trying to identify the problem.
My question:
Is there any known compaitbility issues with the PXI-8512 using the NI-CAN 2.7.4 software installed on a realtime system?
06-11-2014 09:32 AM
Hi DPearce,
The PXI-8512 CAN card uses the NI-XNET driver, not the NI-CAN driver. The latest version of the NI-XNET driver can be downloaded from the following link:
http://www.ni.com/download/ni-xnet-1.8/4166/en/
06-11-2014 11:25 AM - edited 06-11-2014 11:26 AM
Thanks for reminding me about the NI-XNET. I had forget that tidbit of information. I have NI-XNET 1.7.0. I was asking about the compatibility because I had some odd problems before and found out in the end it was a compatibility issue; I think it had to do with the NI-DAQmx software that time. It was real difficult to figure out on my own and I eventually got help from NI Support who knew about it. I don't think I could have found the problem on my own; much of it is a black box to me.
I am about to get the NI-Support folks involved in this issue too but thought I would run down as amny paths as I could before I made the call.
thanks,
Don
06-12-2014 11:07 AM
Hi Don,
What sort of problems have you been encountering with your PXI CAN card?
06-12-2014 04:03 PM
It was a problem with my code. I was posting my CAN messages to a Queue and it was sometimes taking a long time for the CAN message to be actually set. Never figured out why the LAbWindows/CVI 2012 worked better than the 2013 but found a work around so my problem is solved.
