09-26-2018 06:53 AM
Hello together,
I am about to connect the Serial RS232 PXI-8430 card in our PXI-1078 chassis. There are different slots available. Which one should be used for this particular card?
Best regards
Lysandros
10-03-2018 05:54 AM
There is no direct answer for that, you need to specify the application you are working on and the project task, clarify how you are using each module and which one as input module and which as an output.
Also you should clarify what controller you are using with the NI-1078-Chassis? If you don't have exactly a slot on the chassis controller fit the RS-232 you have to us adapter to connect two different types of cables.
Have a look to the features guid, and search for the pinouts part inside the PDF to help on how to do the connections.
http://www.ni.com/pdf/manuals/373170f.pdf
Regards.
Basel
10-03-2018 06:40 AM
As I understand, non-PXI Express cards can be inserted in 'Hybrid' slots, which on the PXIe-1078 chassis can be found on slots 5-9
Dave
10-03-2018 07:10 AM
Agree with Dave, my answer above is for generic cases when the customer wanted to connect one module with another one, in case of several modules project.
10-04-2018 12:30 AM
It fits in one of the Hybrid slots.
Thanks to everybody
