05-30-2022 08:54 PM
Does anyone use PXI-6722 to output sine wave under the below condition?
sweep frequency range : 18~20KHz
frequency resolution : 1Hz
My question is when I add 1Hz and the output signal doesn't add 1Hz, sometimes add 100Hz, sometimes add 200Hz.
Mason
05-30-2022 11:01 PM
Please share the code you use to generate the sweep and scope captures of the generated signal.
06-06-2022 09:53 PM
Hi Santhosh,
Please see the attached file.
06-07-2022 01:00 AM - edited 06-07-2022 01:00 AM
