03-04-2011 05:47 PM
Hi
I was trying to use static generation provided in the examples section for PXI 6542 to write values to first 20 channels. When I was giving the value in the channel list as "0-15", the respective channels were driven to "high" as expected. However, if I mention the value in the channel list as "0-20", channels 16-20 are not driven "high". Could someone please help me in fixing this issue? How should I assign channels in static generation mode?
Thanks!
Solved! Go to Solution.
03-04-2011 08:57 PM
Hello testough,
The examples inside of NI example finder for static generation have a channel mask input. This by default is set for channel 0-15. If you are wanting to have channels 0-20 generate data you will need to update the channel mask to be 0x1FFFFF (a 1 for every channel).
I hope this helps
03-05-2011 12:48 PM
Hello Jesse
Problem is solved!!! 🙂
Thank you very much for your help!
