PXI
PXI-6528 Input Signal Glith Detection
I am using PIX-6528 to read and write digital signals. I have one I/O unit under test which is connected with PXI-6528. As of now I output a value on the Unit Under Test (UUT) and verify the value by reading the PXI. Next task is to detect if there is any glitch in the signal. I tried with different options but I couldn't find any direct solution. I can filter out the glitch with filtering option but how can I get notified when glitch is detected. I am using LabVIEW with DAQmx.
Is it possible to detect the glitch? Any help highly appreciated.
Thank you.
Message 1 of 1
(3,332 Views)
