Using 6123/SCC68, and splitting the +5V terminal to use as simulated input, the range of measured voltage goes from about -1V to +4V. This is from the test panel in Automation explorer, or from a VI in LabView. I know only differential input mode is availble, but then how should we connect the analog input to display 0-5V? Thanks...
