12-15-2021 03:10 AM
Hi, recently I have a problem when I try to use my old program that used for PXI 6115 card with a new PXIe 6396 card.
Actually, my program can not control the data acquization of PXIe 6396, however, in the test panel, there is no problem.
I thought I can use the old program by changing the device channel or ports. Is this right?
I tried to change the slot for PXIe6396, but it made no difference.
My old program was written by C++.
I hope someone can give me some hint to solve this problem.
12-16-2021 02:09 AM
Hello LIFeng,
Which DAQmx driver do you use?
Best Regards.
12-16-2021 03:05 AM
Hi, EdgarU,
DAQmx driver is 21.3, I think the driver has no problem, because I can control 6396 modula through Labview.
The problem is I can use the old program written by other guy with C++(for control 6115). I though 6396 should be compatible to 6115.
12-29-2021 03:37 AM
Hello LIFeng,
Which functionality is implemented based on C++? May you move it to LabVIEW?
Why I ask, since we can make it based on LabVIEW and then save it as C++ DLL.
Best Regards.
