‎06-13-2018 05:05 AM
As for PXI-5114, is it possible to set different vertical ranges to different channels?
For example, I would like to set 1V as a vertical range for Ch0 and 5V for Ch1.
I've confirmed some sample VIs, but in the sample VIs, only one value is assigned to a vertical range for both channels.
‎06-19-2018 08:08 PM
What sample are you looking at?
Are they in NI Sample Finder?
‎06-19-2018 10:16 PM
Thank you for replying!
I made the same question in Japanese Discussion Forums and the issue has been solved.
Please find the link below.
Thanks!
Ishiguro
‎06-19-2018 11:23 PM
Glad to hear!
