I searched the forums for this question but did not get a concrete answer. I'm using a Kulite ITQ-1000 pressure transducer attached to a RDP signal conditioner/amplifier which is then fed into the PXI-5105. The signal has been set so that the maximum rated pressure outputs +10V from the RDP unit. My question is regarding the minimum voltage level... I noticed on the specifications for the 5105 that there is a "Minimum Voltage Range" of -25mV,25mV. Does this mean that the minimum voltage input that should be fed into the 5105 should be no less than, in my case of only positive voltage, 25mV?
