1. Set gain for particular channel using DAQmx Channel -> AI.Gain properties instead max/min voltage?
2. Set DC offset for particular channel using DAQmx Channel -> AI.DCOffset properties? What units of this offset?
3. What properties control LP analog filter? Or this filter always ON? May be this filter controlled by writing F/T to the AI.Lowpass.Enable properties?
DSA modules like the 4462 will remove a DC offset automatically when AC coupling is selected. You'll select AI.Coupling as the property to write in your DAQmx Channel property node. You will not be able to enter a value for the offset. Related info, here.
The anti-aliasing filters on DSA devices are not configurable through a property node. They automatically adjust with sampling rate to follow the Nyquist frequency. The AI.Lowpass.Enable is not a property supported by these modules.
Sure -- there's no way to set a DC offset value for the hardware sampling on the DSA series -- but you could build your own post-processing logic into the acquisition code.
