PXI
PXI-4065 Calibration
Dear Sir / Mdm,
I would like to know if there is a need to perform calibration on the PXI-4065.
This is because, when this item was purchased. There is no calibration certificate attached.
May I know is it necessary to calibrate this PXI - 4065 ?
Thanks and Best Regards.
KT
(1,785 Views)
If you want your instrument to operate within its specifications, you should certainly calibrate it.
If you have NI-DMM installed, you can view its Last Externally Calibrated date either by viewing the device in MAX or by calling niDMM Get Cal Date and Time (LabVIEW) or the language-specific equivalent.
Tobias
Principal Software Engineer
Driver Software
(1,771 Views)
Dear Tobias,
Thank You for your reply.
Best Regards.
KT
(1,757 Views)
