03-24-2020 12:34 PM
Good afternoon,
I am working to design a hybrid board for the PXI-1095 chassis. This board will only require +5V from the chassis, which I plan to get from the JP1 connector that connects into the back plane. I am finding it difficult to find the proper documentation that describes the appropriate pin-out and dimensions of the footprint I'll need to put on the board for the JP1 connector.
I found the PXI Express Hardware Specification documentation, and think table 4-12 describes the pinout information I need (can someone confirm that this is accurate, this documentation is from 2005).
Where can I find the dimensions for the footprint I'll need?
Any help that you can provide is greatly appreciated!
David Durachka
NASA Goddard Space Flight Center
Instrument Electronic Design
03-25-2020 03:53 PM
Hi David,
The most current revision of the PXI-5 spec (which covers PXI Express) is from 2018.
http://www.pxisa.org/userfiles/files/Specifications/PXI5_PXIExpressHW_r11.pdf
With that in mind, though, what I think you really need is the CompactPCI Express specifications. This spec actually covers the mechanical dimensions that you'll need to know. The PXI-5 spec draws heavily on the compactPCI Express specification and references it throughout.
The CompactPCI Express (cPCI Express) specification needs to be purchased from PCIMG. It's not available for free.
https://www.picmg.org/product/compactpci-express-specification-pdf-version/
If you're going to be making your own board, I'd highly recommend you purchase the cPCI Express spec.
03-31-2020 10:03 AM
Thanks for the information, I really appreciate your time!
