PXI
PXI-1042 Intermittent Power Supply Issues
My PXI-1042 chassis will not power on. It was fine a couple of years ago I am
told. It appears that the power supply has gone bad. The p/s fan does not even
come on. Is it possible to purchase a replacement shuttle, and if so, where? If not, does anyone have a suggestion, other than buying a brand new chassis? The task I will be performing is so simple that I can do what I need to do with a Raspberry Pi, but that is not acceptable in this environment.
Thanks in advance.
One should welcome adversity as an opportunity to excel.
(2,319 Views)
Accepted by topic author Daddy-O
You can purchase a new power shuttle for the PXI-1042 using this link and clicking VIEW ACCESSORIES.
The NI PXI-1042 POWER SUPPLY SHUTTLE USER GUIDE walks through how to replace the power shuttle of your chassis.
Marco C.
Applications Engineering
(2,299 Views)
