PXI
PXI-1033 fan specifications
The PXI-1033 chassis powers up (2 green LEDs) and then shuts down in about 5 seconds.  The fan does not spin.   Unplugging all PXI boards does not help.    Found procedure for replacing fan.  Is this the likely cause ?
(4,153 Views)
It may be worth a try, but I would bet it is a faulty power supply.
For this chassis, you must get in touch with NI, and send it in for repair in order to replace the power supply.
You can contact the Applications engineering department by visiting ni.com/ask and creating a Service Request.
Peter Flores
(4,140 Views)
Mine does the same thing...did you ever get resolution on this?
(2,808 Views)
