09-04-2012 07:10 AM
i am getting an error in NI 5622 digitizer PLL could not phase-lock to the external reference clock.i am using daisy chaining the multiple NI 5665
09-05-2012 11:29 AM
What is the error code that you are getting? Also, what is the rate of the external reference clock? Does the external clock meet the Phase-Locked Loop (PLL) External Reference Clock Specifications that can be found on page 13 in NI PXIe-5622 Specifications? Also the following KB article might be useful in your case: Error -1074115830 or -200245 when Using External Reference Clock with High-Speed Digitizers (Scopes)
