06-30-2020 01:44 PM
Hello everyone!
I'm going to by 4ch fast digitizer and my sight was dropped at 5764 model.
Could you say, is it compatible with Matlab?? I didn't find this model in NI-SCOPE , Data Acquisition Toolbox device list.
There s no special external trigger input, instead of this exist digital IO connector. How external triggering could be provide??
I also didnt find any Programming manual on this model.
Thanks.
06-30-2020 02:20 PM
Check the getting started guide for the 5764: http://www.ni.com/pdf/manuals/376460b.pdf
PXIe and PCIe should be very similar. I believe you will need LabVIEW FPGA and NI FlexRIO drivers to run this card.
Do you have plans for what you will run on the FPGA?
07-01-2020 03:42 AM
Thanks for answer.
I checked this manual before and was surprised that theres no separate programming manual like for digitizers from another vendors.
I need to run digitizer under Matlab applications.
-Do you have plans for what you will run on the FPGA?
No matter how strange it sounds, but I need to collect 4ch data with following postprocessing steps.
