Hi
I have a PXI system whose components are
- NI PXIe 1082 chasis
- NI PXIe 8880 processor
- NI PXIe 8431/8 RS485/232 communication card
- NI PXI 2564 Relay Module
- NI PXIe 6361 Multifunctional IO
- GE 5565 VMIC communication card.
My operating system is LabVIEW RT 2015. When I run the PXI without plugging in GE 5565 card, LabVIEW RT operates well, I can see 8 processors on the secreen. No problem. The problem occurs when I plug GE 5565. PXI automatically enters BIOS and gives PCI Resource Error (photo is given). The problem presists even only GE 5565 card is plugged while removing all other ones.
What I have done so far;
- In BIOS menu, Advanced > PCI configuration
-- 64 bit memory mapped IO (Enabled - Disabled)
-- PCIe Max Payload Size (128 Bytes - Auto)
I have tried the four options which are composed of the combinations of the available options in PCI Configuration menu. Any ideas?
Sincerely...
