PXI
Oscilloscope connection NI PXIe-4300
I am a beginner of a Ni device and I would like to ask why the waveform on the oscilloscope is like this when I connect the probe of the oscilloscope to the Al +of the COM1 of the NI PXIe-4300? I'm sure my grounding terminal is intact.I hope someone will answer for me, and I will be very grateful to you.The connection mode and waveform diagram are attached.
(2,127 Views)
The image you posted was captured using an external oscilloscope or using the 4300 AI?
Question - what do you use to generate the signal and how is it connected to the 4300 AI and the oscilloscope probe?
Santhosh
Soliton Technologies
(2,095 Views)
The NI 4300 is housed in the NI 1082 case, as shown in figure, and the image I released is using an external oscilloscope.I connected the Al + of one of the 4300 channels to the oscilloscope probe with a dupont cable, and the Al- connected to the oscilloscope's ground terminal.
(2,090 Views)
Hello, wenxiuluo.
For the first try to check all wires.
Check input impedance to be the same as the source (50 Om or 1MOm)
Check AC, DC coupling.
(2,038 Views)
