PXI
No switch simulated Ni-DAQmx
I have NI SWITCH installed but “switch” is not displayed as a device to simulate in NI-DAQmx. Compatibility, everything installed is version 20.0.
(725 Views)
NI SWITCH uses NI-Switch drivers and not DAQmx drivers.
Please use the NI-SWITCH palette
It has been a very long time since the NI SWITCH driver took over all switch related functionalities from DAQmx (may be still supports a few but not recommend to use DAQmx driver)
Santhosh
Soliton Technologies
(707 Views)
Switch is not present for simulated NI-DAQmx Device. Even though NI-switch is installed.
Is there a config file or something?
This is a reinstall of LabView worked prior on old install.
(683 Views)
Looks like you did not install NI-SWITCH drivers
It should come up like this,
You can install NI-SWITCH drivers from NIPM as part of Device Drivers or individually from NI website - https://www.ni.com/en-us/support/downloads/drivers/download.ni-switch.html#345632
Santhosh
(679 Views)
