PXI
NI-XNET - Invalid CAN interface
Hello Guys,
I am trying to communicate with 8512 CAN Module using PXIE Hardware, the same error is arriving when i run the LabVIEW example code. Mr. Ulfjon have mentioned that you need to close the NI max session. I did not create any sort of session in the NI Max though in NI Max am getting the results(CAN DATA) properly and not in  the LabVIEW code, can someone help me about this?
Thanks in advance.
Message 1 of 1
(2,312 Views)
