PXI
NI PXIe1071 Fan Replacement
I'm using NI PXIe-1071  and PXIe-8840 Controller.
I am suffering from the fan noise so I decided to change the cooler.
I bought Noctua A12x25 system cooler, which is quite famous for its low noise and high cooling performance.
The Fan size is good to adapt to the chassis but the 4 pin connector type was different.
I want to know the size standard for PXIe cooler and  it would be greatful is you know any product that can adapt those different type of 4 pin connectors.
thank you : )
(747 Views)
Hello KyleLee,
I would like to inform you that NI recommends using/buying a subpart of the system from the NI. In otherwise, you will lose your warranty.
So, concerning this case, you should contact NI technical support for performing any replacement. They will check in their said concerning this, or similar fan is available for this chassis. And perform the right path for the replacement, your cooling system.
Best Regards.
(693 Views)
