07-20-2011 10:33 AM
I would like to know if the PXI-8108 RT with Real time 2009 controller is compatible with the PXI-1050 chassis. Since the 8176 controller is a bit old, I am not able to find the relevant information on the website. Can somebody please help me. And if in case this is not compatible can you please suggest a suitable solution.
Solved! Go to Solution.
07-21-2011 02:01 PM
The PXI-8108 should work just fine with the PXI-1050 Chassis. The only requirement is a PXI chassis uses a PXI controller and a PXIe chassis uses a PXIe controller. Since both the 8108 and 1050 use the PXI standard, they should function just fine together.
Eric
