PXI
NI PXI-5124 High Speed Digitizer, Timing Issue, don't have Extract Single Tone Information VI
So I am trying to complete a verification on a PXI 5124.
I do not have the full development version of labview, just the basic development version.
I am trying to complete the timing checks as in the procedure but I am at a point in which I am told to use the Extract Single Tone Information VI;
10. Measure the exact frequency of the peak around 11 MHz using the Extract Single Tone
Information VI with the following inputs.
advanced search»approx freq.: -1
advanced search»search: 5
export signals: 0 (none)
11. Calculate the error in timing as parts per million (ppm) using the following formula:
error = (a - 11,000,000) / 11
where a is the measured frequency.
Compare the result to the Calibration Test Limits or the Published Specifications listed in
Table 11. If the result is within the selected test limit, the device has passed this portion of
the verification.
Does anyone happen to know another way around this?
Because I don't have the extract single tone information VI.
Thank you, any help would be much appreciated.
(2,047 Views)
Hi Darkbaney,
What procedure are you referring to? What is the end goal?
Chase
NI Technical Support Engineer
(2,023 Views)
