PXI
NI PXI-2530b mux speed and NI PXI-4141 smu bandwidth
I'm working with a chasis with a 2530b mux and a 4141 smu connected each other. I have two questions.
The first and more easy one, which is the bandwidth of the smu 4141??
The second maybe is a little more complicated, I'm using python to control the 2530b and I have a small problem with the switching speed between channels, basically I want to switch to one channel on the 2530b, gather a determined number of data points with the 4141 and start over again (switch to the next channel, gather data, ...).
I achieved to do it without problem, but is relatively slow, it takes approximately, 13 ms from one channel to the next one. I'm pretty sure that the multiplexer can go way faster than that but I don't know how. There is some code to make this kind of measurement? Or there is some command manual?
Thank you for your time.
Message 1 of 1
(3,102 Views)
