PXI
NI MUX 2575 CH24 closed R>3Ohm
Hey,
we have a NI MUX2575 where CH24 shows an extra 3 Ohm (or more) when closed.
Is this out of spec? Should I launch a SR (Service Request)?
thx,
Koen.
(1,723 Views)
Accepted by topic author kdCMC
As per the spec sheet, anything above 1 ohm is a relay at the end of life.
Looks like you need to replace the relays to get them upto specifications,
Relay replacement guide - http://zone.ni.com/reference/en-XX/help/375472H-01/switch/2575_relay_replacement/
Specifications sheet - https://www.ni.com/pdf/manuals/373870n.pdf
Santhosh
Soliton Technologies
(1,677 Views)
