07-23-2021 05:03 PM
I have a PXIe-8133 controller (Windows 10) installed in a PXI-1078 chassis; the chassis is full of assorted cards (timing, FGEN and DAQ) When this controller was initially setup, it was installed in a PXI-1071 chassis, and NI-MAX still identifies that that chassis as being installed. As a result (assumption), none of my cards show up under the chassis, though they do show up at the same level as the chassis. The only items shown under the chassis are the controller and the GPIB port. How can I reset my NI services so that they will read the new controller/cards?
I have tried:
* NI-MAX Refresh
* Re-installing drivers (VISA, DAQmx, etc)
* Resetting Configuration Data (from NI-MAX)
* Deleting the Data folder
The pxisys.ini file contains the same configuration information as NI-MAX (of course). Is deleting that file an option?
Solved! Go to Solution.
07-23-2021 08:42 PM
I have read another article that NI support suggested deleting pxisys.ini to reset the PXI configuration detected by NI MAX.
Please refer to these articles on pxisys.ini file usage,
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8vBSAS&l=en-US
07-26-2021 08:36 AM
Thank you for your reply! The solution ended up being to
1) Add a chassis in NI-MAX (PXIe-1078 was autodetected)
2) Delete the new chassis
Now I've got 1 chassis with the correct cards in it. Success!
