03-14-2013 11:06 AM
HI
I have a new chassis 1073
Thanks for help
Dina
03-15-2013 08:39 AM
Dina,
Here are a few things to check.
- A5/B5 should be connected to the PLX 8311's TX lines through capacitors (standard PCIe levels). TX --> cap --> A5/B5
- C5/D5 should be connected to the PLX 8311's RX lines (standard PCIe levels). RX <-- C5/D5
- Refclk is not a standard PCIe level. It's LVPECL instead. So it should should be AC-coupled and rebiased/terminated. As I recall, this suggested bias is a 56 ohm resistor to GND and a 475 ohm resistor to 3.3V (50 ohm Thevenin equivalent, center point of voltage around half the normal swing of PCIe's HCSL clock lines). The PLX bridge may have different requirements. RefClk <-- [bias resistors] <-- cap <-- E4/F4
- PRSNT# (A2) should be pulled down or connected directly to GND, though it's not used in a 1073.
Robert
03-18-2013 08:34 AM
Hi
Thanks for help. I give your infornation to my hardware engineer. You need do change to our print
Best regards
Dina
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
