11-07-2005 06:57 PM
11-08-2005 11:49 AM
Hello CXROGuy,
What kind of service is communicating with your PXI Chassis? If it is an executable, you could try having it run at start up. To do this you will simply need to place your .exe in the Windows Startup Directory. Follow the instructions in the following Knowledge Base to do this:
http://digital.ni.com/public.nsf/websearch/8B0772F1E926C55D86256EE900778BDE?OpenDocument
Does this answer your question? Please let me know if you have any further questions.
Sean C.
11-08-2005 12:25 PM
11-09-2005 03:20 PM
I just found the following Knowledge Base on Microsoft's site:
http://support.microsoft.com/default.aspx?scid=kb;en-us;193888
I believe this is the information you are looking for. This Knowledge Base details how to make one service wait on other services before starting.
Let me know if this does not help.
Sean C.
11-09-2005 03:49 PM
11-10-2005 12:03 PM
Without knowing exactly what you are doing, it is hard for me to say which NI service could be causing the problem. I agree that the most likely suspect would be the nipxirmu service. But if that does not solve the problem, I would recommend trying some of the other NI services that are listed.
Let me know your results.
Sean C.
