10-03-2012 10:05 AM
Hi All,
I am trying to co-simulate a multisim file into Labview.
Its working but the moment I select that VI to run in real time FPGA , everything codded in labview works but the multisim block stops talking to my PXI.
I do not understand why is this happening. Can anyone help me.
A.A.K
10-04-2012 09:56 AM
Hi A.A.K,
Can you send us your files. It you do not want to share them on the forum, you can go to www.ni.com/ask and create a Service Request.
10-04-2012 12:59 PM - edited 10-04-2012 01:11 PM
Hi Tayyab!!
Files are attached. Its simple PWM genration from multisim called in VI.
Tell me if co-simulation does not support FPGA at all, because the multisim block always stops running whenever i connect to FPGA (PXI-7813).
AAK.
10-05-2012 03:09 PM
Hi A.A.K,
The Multisim co-simulation is intended to help you simulate the circuitry for your system but it is not possible to add this on the real time target device(PXI in this case). You can still test along side your FPGA code on your computer and test the system but it can't be launched into target devices.
Hope this helps.
10-05-2012 03:31 PM
Here are a couple of useful links you can look at. In general, you can use co-simulation with IP FPGA nodes.
10-08-2012 08:13 AM
Thanks Tayyab !
I think I need to start coding myself.
AAK.
10-21-2012 06:54 AM
Hi Tayyab !
