PXI
Measure the time difference between a digital output and a responding analog input
Hallo,
I use the following system:
  • NI PXI-1044 with NI PXI-8109 controller
  • NI PXI-2564 switch module to turn the power of my tested device on
  • NI PXI-6259 multifunction DAQ to measure the responding signal jump
Both cards are at the same PXI-trigger-bus. For both, PXI-2564 and PXI-6259 I use DAQmx to program reading and writing the channels.
Now I want to measure the time delay between the digital output, that switches my device on and the analog input, that measures the reaction of my system.
I can't get it to work by myself, please help me!
Thank Ludwig.
(4,146 Views)
Hi Ludwig,
what have you tested so far?
Do you have any VIs which you can upload for us?
Abduelkerim
Sales
NI Germany
(4,127 Views)
The M-Series synchronisation mechanism dosn't work.
I don't know if a could address the PXI-trigger-bus directly?
(4,120 Views)
I did understand your problem.
But you said: "I can't get it to work by myself"
Therefore, you definitely have build some VIs. I would like to see them
Abduelkerim
Sales
NI Germany
(4,117 Views)
I have not any VIs. I had one but with every error I changed it to try other things. Because of no usable result I didn't saved anything.
(4,111 Views)
Accepted by Ludwig72
Hi Ludwig,
if you can't give us any VI we have difficulties with helping you.
Because I donÄt know how your programm is build up it is not easy to tell where you should grip signals.
Here is a similar question to yours:
http://forums.ni.com/t5/LabVIEW/Best-way-to-measure-time/td-p/178704
and 2 external links:
http://www.ehow.com/how_8698983_measure-time-labview.html
http://objectmix.com/labview/385152-how-can-i-use-labview-measure-time-between-analog-pulses.html
Abduelkerim
Sales
NI Germany
(4,095 Views)
Hi Abduelkerim,
thank you for your help.
I wish, there was a function to use the PXI trigger bus to synchronize measurements.
Timer and Timestamps are not the exactest but an usable way.
Ludwig.
(4,086 Views)
