@David22JRA wrote:
Hello @Wolleee
Just be completely sure. You could not see the other cards into the chassis, right? Or you could not see the controller MXI (8360)? Have your tried to install the DAQmx Driver and restart your computer. On the other hand remember that is pretty important turn on your PXI first and after that turn on the computer.
Regards
Thank you for the reply David,
Actually the problem was that tiny little dip switch on the PCI express board that you install into your PC. Normally it probably wouldnt be an issue, but i inherited the chassis from someone who apparently turned on the first switch for the Bios compatability issue. I had to slow down and really read through those manuals and start from ground zero. I reset the switch and all is good.
But thank you for your help.
Matt
-Matt
