Dear all,
I have a chassis PXI-1002 with a controller PXI-8175, and I want to use all 4 solts of the chassis, however in MAX is showing up correcty only the card in slot 2, to exclude the problem of the MAX I have tested the cards with another chassis (PXI-1033) and every thing is fine as well their drivers.
I have also changed the cards position to be sure, and my final conclusion is that there is a problem with slot 3, and 4.
As you can see from the MAX figure, the card in slot 2 is recognized, the card in slot3 with an x sine ???, the worst is with card in slot 4 which is not showing up??
any clues??
thanks
