PXI
Looking for driver for ven_1093&dev_730e for vista
I have one device that is not recognized by windows vista.
The device according with the device administrator is ven_1093&dev_730e.
I am using Windows VISTA SP2
Message 1 of 8
(4,633 Views)
Hello
Please can you reply with the hardware you use for serch the drivers you need.
Thank you.
Message 2 of 8
(4,627 Views)
Hello
You see the hardware in te attached image, obtained from MAX. I have two PXIe 1075 connected with PXIe 8374 and 8370
Best regards
Message 3 of 8
(4,625 Views)
Sorry, I have forgotten to attach the image
Message 4 of 8
(4,624 Views)
Hello.
I think what you need is download the drivers from the link i attach.
Please follow the steps and it would run correctly.
http://digital.ni.com/public.nsf/allkb/1B9F749F23CC9F838625746B00599242
Best regards.
Marcos
Message 5 of 8
(4,620 Views)
Device 0x730E is a PXI-4130.  Do you have one of those in your system that isn't in MAX?  I haven't used one, but you probably need DAQmx for the driver.
- Robert
Message 6 of 8
(4,612 Views)
The PXI-4130 uses the NI DCPower driver. The latest version to date can be downloaded here:
NI-DCPower 1.7 - Windows Server 2008 R2 64-bit/Server 2003 R2 32-bit/7/Vista/XP (SP2) 32-bit
Steve B
Message 7 of 8
(4,607 Views)
Hello
Tomorrow I will install the NIDCPower Driver. I have  a PXIe 4130 installed but I haven´t installed the driver. I think that It could be the problem.
Tomorrow  I will tell you if all is correct
Thanks and best regards
Message 8 of 8
(4,602 Views)
