02-08-2007 05:33 AM
Solved! Go to Solution.
02-09-2007 02:02 PM
02-11-2007 05:29 AM
02-12-2007 03:38 PM
02-14-2007 11:35 PM
02-15-2007 04:34 PM
02-16-2007 12:54 AM
02-19-2007 11:45 AM
07-22-2009 03:30 AM
Hi everybody,
I am trying to run an application which runs continuously recording peace of signals or if a critical event is detected run a trigger and save some signal. The problem is that after some hours (2 to 7 hours depending on the computer) the program stop displaying the following message: Labview: memory is full!!
How can I solve this problem?? I am also attaching the VI.
Thanks!
07-22-2009 03:37 AM
As an option to solve the same problem previously posted I also develope another program. In this case the program runs a bit longer (9 hours or so on) but the message that labview is without memory is displayed again:
Labview: Memory is full
VI was stopped at unknown at a call to vi: Instance:0
I am ataching the VI.
Thank you very much for your help!
