08-13-2009 12:13 PM
03-17-2010 09:51 AM
Not sure this is the same issue you are having, but my copy of LV2009 (SP1) suddenly started giving me a "LabVIEW 9.0.1 Development System has encountered a problem and needs to close" system error while initializing plug-ins during startup and would not run. I focused on the plug-ins and checked the NI License Manager and looked under LabVIEW 2009 SP1 Modules and found a copy of the FPGA module had inadvertently been installed but was showing red as its evaluation period of 30 days had expired. I uninstalled the FPGA module and then LabVIEW worked fine after that.
03-17-2010 09:54 AM
Here is a link to a thread with similiar problem in LV 8.6:
http://forums.ni.com/ni/board/message?board.id=170&message.id=369469&requireLogin=False
06-11-2010 02:53 PM
As similar to the link listed in the thread, I had the same problem yesterday. Repaired Labview 9 but no change. I got rid of the Labview RT components as it only had 1 day of evaluation left on it. The problem when away and version 9 is back up an operational.
Hope this helps.
07-08-2010 02:55 PM
I get this error Labview cannot continue ( when loading plug ins), so based on this thread I tried to purge all the evaluation ware,
but can't locate all of it in add/remove programs. The name in license manager does not allow one to determine which
feature to remove to get rid of it.
That's after fixing a problem where the installation messed with my
gateway settings and disabled my network connectivity.
labview tpwcebuilder pocketpcbuilder realtime dsc statechart are hidden in something else so I can't get rid of them.
07-09-2010 02:32 PM
You should be able to see these in Add/Remove Programs after you click on National Instruments Software then 'Change/Remove'. You can confirm what software you have both here and in Measurement and Automation Explorer.
