A little while ao someone posted a Raw socket ping for Win2K. I've
included the .llb here. You can use this from a PXI running Windows. I
have not tried it with an RTOS system.
I've tested this .llb on my winXP machine and it works quite fine. I still haven't tried it on RTOS, but I found that it uses a shared library called ws2_32.dll, which I found on my windows/system32 directory. However I'll see if I can make it run on RTOS and I'll be telling you how was it.
Daniel,
I would be surprised if you are able to get that library working using
the RTOS. One way to do this would be to simply open a TCP
connection to the target IP address and see if it times out, then
handle your various cases from there.
Doug M Applications Engineer National Instruments For those unfamiliar with NBC's The Office, my icon is NOT a picture of me 🙂
