06-14-2010 05:26 AM
During the test execution in my project, I'm using PXI 4130 to force a voltage for a certain amount of time. At some Later Point, I'm using another source to force the same node, and I need PXI 4130, NOT to load [move to High Z / isolate] my other source. The output Disable VI doesnt moves the output to a low resistance. Please Help.
Manu
06-22-2010 09:06 AM
Hi Manu,
Unfortunately the 4130 does not have the ability to disconnect the output like the 4132 does. Here is some information about disabling the output from our DC Power Help:
I would suggest that you could implement this type of behavior using a relay at the output of the 4130. This would give you the ability to disconnect the 4130 from your test pin.
