08-02-2012 09:13 AM
I am currently trying to work with CANOpen. I am using a PXI 8513 with an 8133 embedded controller, then a NI 9862 CAN card (with cDAQ 9178), and a CAN breakout box. I am wondering if the PXI 8513 is compatible with the CANOpen labview library, and if it is not, can I somehow make it work with a different driver? Or, is my only option to purchase the NI PXI-8461/2 series 2?
Thank you,
Anthony
08-03-2012 11:55 AM
Anthony,
In fact the PXI-8513 would probably be a better choice for using the CANOpen Library as it is one of the pieces of hardware fully supported by the library while the PXI-8461 is not.
You can find the CANOpen Library help manual here. Below is a screenshot of the page that describes hardware compatibility.
Hope this information helps! Best of luck with the application.
-Nick-
08-27-2013 03:21 AM
Hi Guys,
I have the same question. Thanks for the link to help file, but in this file the the PXI-8531 is listed as supported device. I also plan a PXI-8513/2 with the 2 interfaces. One should be used as Standard-CAN, the other port should be CANopen. With the "old" hardware XS-Series 2 this option is supported by using the Standard Frame API on Port 1 and the "old" CANopen LabVIEW Library on Port 2.
How would I do this with the X-NET-Hardware?
Possible solutions I see:
Option 1: I use the compatibility layer and use the old versions of the NI-CAN-API which I won't prefer due to old and not recommended API on CAN and CANopen.
Option 2: I buy a 8513 and a 8531 which I won't prefer at all.
Does anyone see other options due to CANopen Interface Create.vi does not accept my 8513 hardware.
Thanks in advance.
Tyler.
