‎06-18-2025 04:51 AM
We will be using the PXIe 4302 with the 96p DIN connector. Unfortunately that connector is too big for our end application.
Are there other cables available, besides the SH96-96-2 with a different end connector?
Or is it possible to remove the male connector and attach a different on to the SH96-96-2?
Or is there a PXIe 4302 variant without a backplane connector on the front?
Kind regards,
Bram
‎06-18-2025 08:10 AM
You need to create your own breakout cable into custom connectors, currently NI expects you to use a 96-pin to terminal breakout board or incorporate the 96-pin connector into your test fixture.
You can use a breakout board to form another custom cable combination.
https://www.winford.com/products/brkn4296.php
How many of the 96-pin do you need to route to your application?
‎06-18-2025 08:33 AM
Could you tell me if the DIN 96p has crimp or solder contacts?
‎06-18-2025 09:45 PM
If you're asking the construction of the male-female cable, from the looks of it, it may be wires soldered to the connector through a PCB under the case.
I/O connector
Male ..........................................................96-pin Type R DIN 41612/IEC 60603-2
Female.......................................................96-pin Type C DIN 41612/IEC 60603-2
